31-07-2024 08:33 PM
I seem to be having the same or similar problem.
Intermittent data connections and but no calling possibly.
I can't even make WiFi calls to CS.
31-07-2024 08:36 PM
Rather than add to someone else's thread, it may be more helpful to explain your issues from scratch. As a basic - does your phone show a connection to a local network in the country you're visiting? You need network coverage to make & receive calls, send & receive text messages and use mobile data.
WiFi-calling is not supported abroad.
