Roaming abroad
Cobyallen
I’m currently in Africa, Malawi and my EE sim is saying no service. Last year I was helped when this happened but I forgot how. Can someone help as I need to turn it on to make and receive calls
In which case... Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks.
Did you use the exact same SIM in Malawi last year? Have you ever requested that the roaming facility was removed from your SIM?
Try manually connecting to each available local network in turn.
I’m currently using a different a sim right now
