Re: Not registered on network
Emsndem
Hello I clicked it on it is said it was fine but it still says not registered on network ols help since I have a lot of things connected to my number
James_B
EE Community Manager
Hi @Emsndem,
Are you using a pay as you go or pay monthly plan?
Are you in the UK or roaming?
Pay as you go an in the uk
James_B
Hi @Emsndem,
When was the last time you used your phone for a chargeable action?
Sounds like your PAYG SIM has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
