Re: Not receiving text messages from UK whilst abroad.
Andy12345678910
...I am roaming on ee in Ukraine, txt msg from UK just stopped
Does your phone show a connection to a Ukraine network? Can you make & receive calls OK?
Have you tried connecting to an alternative local network?
@Andy12345678910 : Can you make calls or send texts?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Hello
I have a problem with my SIM card
I can’t activate roaming. It doesn’t let me to receive txt or calls. Also I can’t receive calls or txt messages
It does show connection, but I cannot make or receive anything
Leanne_T
Hi @KharkoM
I am sorry you are unable to use your SIM card when roaming.
Do you have a pay monthly or pay as you go account?
Have you tried manually connecting to another network?
Speak soon 🙂
