on 24-03-2024 09:01 AM
Hi. We’ve just got to Paris. I set up my roaming but I’ve got no signal. I’m currently being hotspotted to be able to use this website. I’ve tried turning aeroplane mode on and off and also switching my phone on and off. Can you help?
on 24-03-2024 09:18 AM
@Robynj86 : How have you gone about setting up roaming?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
