Re: Get busy message when making outgoing calls after 4 rings
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 02:11 PM
I am having the exact same problem - have you solved it?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-08-2024 12:24 PM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 02:47 PM
Can you receive calls and send texts?
Do you have a new EE SIM card?
Thanks 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 03:04 PM
Yes, I can receive calls and send texts. I have a new EE SIM. My problem is exactly the same as the post I was replying to.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 03:39 PM
I should also say that I am using this SIM in a new Nokia 105 as a very basic PAYG, so I don’t know if the problem is with the SIM or the device.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 04:06 PM
Thanks for the extra details 🙂
Could you try extending the ringing time to see if this helps by typing this directly into your phone's keypad (you may need to hit the call button too):
**61*07953222222**20#
If that works, it should change it to 20 seconds before the caller is directed to voicemail if this is set up or a call busy message.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 04:22 PM
Thanks Leanne. I typed this in and pressed call and got a reply that confirmed it - can’t remember what it said exactly. Then I tried calling my landline but there is no change. After 3 rings I get the number you called is busy message. But my landline is not busy. And even if it was, the call should have gone to voicemail. When my friend rings my landline and I don’t pick up, the call goes through to voicemail after a good number of rings, which is as it should be. So it seems to be only my new mobile and SIM that is having the problem.
Not sure who you mean be ‘the caller’ - does that mean me calling out?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 04:24 PM - edited 19-12-2023 04:25 PM
Sorry for any confusion, this would help for people calling your mobile number not calling out.
Is this happening when you call any other numbers or just the landline?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 04:54 PM
I just tried calling my mobile from my landline and it took 20 secs to go through to voicemail so I suspect the code you gave me has changed the time it takes for PEOPLE CALLING ME to go through to voicemail? Whereas my problem is with ME CALLING OTHERS from my mobile and getting cut off with the busy message (number you are calling is busy) after only 3 rings.
Caps only to make this clear - I really appreciate your help Leanne.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 05:05 PM
Thanks, I understand @Springgreens
Have you tried restarting your phone?
Did you transfer your number from another network or using a new EE number?
Leanne 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-12-2023 05:06 PM
Yes, seems to be happening with any number I call.
