on 24-01-2024 10:43 PM
Yes can't use phone aboard
on 24-01-2024 11:14 PM
Does the phone show coverage of a local network?
If yes, what happens when you try making a call or sending a text?
on 24-01-2024 11:46 PM
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
