05-08-2024 02:19 PM
Hi
My outgoing calling is disabled on my phone!
I'm abroad and unable to use my phone.
05-08-2024 02:26 PM
What makes you think your issues are an outgoing call bar? Can you explain your symptoms?
Does your phone show coverage indicators? Can you receive calls? Can you send text messages?
Are you on PAYG or pay-monthly?
05-08-2024 02:33 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
