17-07-2025 01:36 PM
Hi everyone,
I have a UK EE number and I’m currently in Cyprus. I recently topped up £5, but calls and outgoing SMS do not work. In the EE app, it says that a £10 pack is pending and will be activated when I top up more than £10. But I do not want to use any packs — I only want to pay standard PAYG rates.
At the same time, I suspect roaming is not properly enabled on my line — I can’t send any SMS, not even to 150. Outgoing calls also don’t go through. I tried calling EE support, but the call stays silent and does not disconnect. Incoming SMS do work, so I know the SIM is still active. Outgoing SMS do not work, even though the SMSC is set correctly.
So here are my main questions:
Do I really have to top up another £5 to activate that £10 pack?
What happens when that pack expires — will I be stuck again with no service until I top up for another one?
Is there a way to disable this pack and go fully PAYG, with no automatic bundles and using my current £5?
How can I check if roaming is enabled on my line if I can’t send SMS or call?
I would really appreciate any advice from others who’ve dealt with this. I can’t get in touch with EE support, and there’s no live chat. Maybe someone here can help.
Thank you in advance!
17-07-2025 01:46 PM
17-07-2025 01:58 PM - edited 17-07-2025 01:58 PM
No, this SIM card was activated while I was already in Cyprus. Returning to the UK is not an option right now. So does that mean I should just throw the SIM away, since there’s no other way to make it work?
As I understand it, the £5 I topped up is lost anyway? There's no way to transfer it to my another number (not on EE)?
17-07-2025 03:08 PM - edited 17-07-2025 03:08 PM
