on 27-11-2023 12:51 PM
Hello
There is no signal on my phone, my phone singnal is EE from England but i fly to USA and I do not have a signal.
please tell me how can I contact EE,
kind regards
on 27-11-2023 01:01 PM
@ParthAngre : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
