on 20-10-2023 05:14 PM
Hi
I set up my roaming this morning came to Spain no signal . Contacted ee said I can't use it abroad on my tariff? Why could they not tell me before I came ?
I am left with no way to contact family who don't use WiFi. Its kind of ruined things I offered to pay but declined .
on 20-10-2023 05:20 PM
@moll : What tariff/plan you on?
on 20-10-2023 05:21 PM
Enabling roaming is free of charge, how did you set it up?
If you're on pay-monthly, it's usually enabled by texting ROAMING to 150 before leaving the UK. Did you do this?
I'm not sure what your query regarding billing add-ons is, but if you're within the EU then the cost is either £2.29/day or £25/month for the Roam Abroad pass.
