Not registered on network
DREAMCATCHER64
I recently moved back to EE from BT as I got a new Galaxy Flip 5 phone. But I can't make calls or send or receive texts as I am not registered on the network  - That's the message I get when I try. I can't even call 150 to ask for help. What do I do?
Northerner
Hi @DREAMCATCHER64
Did you get the device from EE.
Are you on EE PAYG or pay monthly contract.
Are you in thd UK.
Northerner
Hi @DREAMCATCHER64
Are you in thd UK.
DREAMCATCHER64
Yes - phone came from EE.
I am on a monthly contract.
I live in the UK.
Christopher_G
Hi @DREAMCATCHER64
Have you tried restarting the phone? Are you using the new EE SIM card?
Oh  - I'm not. I put in my old sim card with my number on it. That may be the issue. I'll swap the sims over. Thank you for your help.
Christopher_G
Yeah, give that a try, @DREAMCATCHER64. Hopefully it then works OK. 🙂
