No signal in Mexico city
Carole32
I have been in Mexico forthree days bought a roaming add on at a cost of £25 and I have no signal
turned on data roaming
tried everything I can think of
can anyone help
Schockwave
Hello @Carole32 ,
Welcome to the community,
I take it you are on a monthly contract with EE.
Did you activate roaming on your account, if not that is why you would have no signal. Buying a roaming add-on does not activate roaming, this needs to be done on your account.
You will have to contact EE to get this activated, which you can do by ringing them  on +4479639661150 or if you have something like Skype, you can ring them for free using this number +448000798586.
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
