Oxford mobile signal
Osborne3
I live in the Oxford area and have absolutely no signal when in the house and nothing when outside until im at the city centre I only live a 10 minute bus journey away can anyone please explain
9 REPLIES 9
How long have you had this problem?
You can check for local network issues using the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker
Since I've moved to ee about 3 weeks now I've checked and says there is an issue
Chris_S
Hi @Osborne3
If you're struggling to get a signal, you can connect your phone to WIFI calling.
WiFi Calling lets you make and receive calls and texts using WiFi, even without mobile network coverage.
You only need a phone that supports WiFi Calling and a WiFi connection in the UK.
WiFi Calling is available to anyone with EE who has a compatible device. To see if your phone supports WiFi Calling, check the device specifications in our device guides.
Chris S
I understand that but its not just the fact its at home i no no signal nothing until I reach the city centre
Hence asking at 9.12am for you to check the status tool, and you responding at 9.50am to say you'd checked it.
WiFi-calling will help with any indoor coverage issues whenever they happen for whatever reason, it would be a poor show if it were not offered in response to any coverage complaint.
@bristolian , you say that you checked and that there is an issue where you are, so have you also registered and reported it? You will get updates, not sure why there is a problem there, could be the mast is down, they are having to move it, as the landowner has decided to not have it on his/her land and they need to find somewhere to put it, could be any number of reasons why this happens, we have no idea here why, this is not customer service, so you would have to speak to them and they may have an answer.
Leanne_T
Hi there @Osborne3
Just to add to the advice provided, we have a network post for Coverage in Oxford that is updated when we have new information.
I'd thought of the NTQ situation in Oxford, but this appeared to be a different scenario. The OP in this thread explicitly mentioned coverage  when at home "10 minute bus journey away", and of service recovering near the town centre.
The opposite of what I know you're alluding to!
Leanne_T
Thanks for keeping me right @bristolian 🙂
If you would like the issues you are having looked into, to see what could be causing this, please get in touch and the team will be happy to help @Osborne3
Thanks very much 🙂
