01-07-2026 05:44 PM
I have been a Small Business customer in the SY13 area for about 2 years, and ignoring the fact I cannot manage my account online (EE still haven't fixed the issue), I constantly have network issues.
My setup is Dyfed Telecom installed a Satellite on the roof with an EE 4g SIM. The satellite is aimed at the new 5g cell tower mast near Prees Heath.
My partner and I work from home full time, and we have airbnb guests, so reliable network is important to us.
Some hours we can get between 20-30mb download and similar upload. This is way better than BT or Sky broadband (6-8mb), but then mid-day until 9/10pm the speeds bounce between 6-15mb download.
We are not a busy city, yet traffic on the mast consumes the network, and I'm at a loss what to do. Joining Teams calls becomes painful and sounds like we are R2D2. Streaming TV shows takes forever.
Does anybody out there have any guidance they can provide on how to ensure our network doesn't get impacted by this ridiculous clog of traffic?
Dyfed tried testing pointing the satellite towards Wem, Shrewsbury and even 2 in Whitchurch. The Prees Heath gave the best signal but it's entirely unreliable on speeds. It's 100% not the equipment as that's all been replaced by Dyfed thinking that was the cause. It's 100% EE and traffic on the mast.
01-07-2026 06:26 PM
I presume your reference to satellites and 5G is a terminology thing, all of EE's sites are multi-technology and carry combinations of 2G, 4G & 5G across different frequency bands. Low-bands provide better coverage whilst high-bands provide more capacity.
The speeds you describe should be quite capable of video-streaming upto 1080/HD standard, which broadly requires perhaps 3-4Mb/s depending on source. You're otherwise just at the mercy of varying traffic levels.
The resolution for slow data speeds is to either reduce the load on your serving site/sector, or to increase the capacity available from it it.
02-07-2026 08:34 AM
I apologise for not knowing the right technical jargon. I'm a customer who is only using the terms EE and Dyfed have referenced.
Streaming isn't my main issue. We work from home, and 3mb doesn't suit a Teams or Zoom call.
Do you have a solution or just commenting for the sake of commenting?
02-07-2026 09:42 AM
Does an EE handheld phone achieve similar speeds to your in-home setup?
That would further demonstrate whether the variable speeds are due to network-side loads, or an in-home issue. If they're network-side, then the fix is network-side also.
02-07-2026 12:49 PM
That is an unknown. I do not have EE mobile for any other device. Our personal mobiles are Vodafone and Three.
Dyfed, however, stated they constantly have to battle traffic load issues with EE who say they won't investigate or upgrade masts because they claim it is too expensive. I am told users just have to accept the inconsistency, despite the fact we aren't even near any major cities.
02-07-2026 04:34 PM
@cotonestate wrote:EE who say they won't investigate or upgrade masts because they claim it is too expensive.
There's a breakdown in communication here, or some misinterpretation.
Capacity uplifts on radio sites are a BAU process for EE and all operators. Some upgrades are simpler than others, and lengthy delays are often caused by site-specific issues.
04-07-2026 05:13 PM
EE customer service isn't going to help me with that. They'll keep asking me to try the sim in another device. They won't investigate the traffic on the tower. I've read enough of boards on here in the last week to know I'm not alone. So what can I do?
05-07-2026 09:49 AM - edited 06-07-2026 10:13 AM
Hi @cotonestate
Our tech guides will have a process they have to follow when looking at any reports of signal problems, and it will involve trying the SIM in another device to rule out other possibilities and get to what is happening.
I understand what you are saying about what Dyfed Telecom are telling you, but our team need to follow the steps themselves and cannot just take word from a third party when it comes to network performance.
The best option would be to contact them again and follow the steps that they suggest so that they can get this looked at further.
Michael
06-07-2026 01:09 PM
Who has marked this as a solution??
Thanks for the tip. It would have to be Dyfed who contact EE on my behalf while on the roof with the sim card swapped. I dont have this option to climb up and swap it.
I will share with them your recommendation and when they've been able to take action and it works...then this would be a solution
17-07-2026 07:46 AM
I've had Dyfed Telecom come visit again to see if they can troubleshoot my unstable network. They have identified the issue - while my sim card is up to 5G capable, the satellite dish (MikroTik) is only 4G. However it can handle up to 100mbps.
We did a number of tests over a couple hours, and speeds fluctuated between 9mpbs and 23mpbs download (30-40 upload).
They tested on a 5G satellite dish (which wasn't available when I first started with Dyfed & EE), and download was 129mbps!
So the issue is not the sim card - and it's not the satellite - it's the 4G network coming from the local mast.
Does anybody have any tips on how to approach this now with EE? There is too much traffic on the 4G network and that's why my network is unstable.
