My phone won’t call aboard
EEuser12342
I live in the UK, I’m on holiday in Greece and when I go to make a call on my iPhone 13 my 5G disappears and I can’t connect a call?  Any help I’d  be grateful
@EEuser12342    Try manually searching for a different network and selecting a different network to the one you are currently connected too.
Have you been able to use your phone in Greece previously? Did you receive a welcome text message on first arrival in Greece?
@EEuser12342 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
