Roaming in Greece
momar1
I have roaming as part of my plan where there's a flat daily fare to use my sim abroad. I've adjusted the spendcap aswell.
However I can't connect to any of the local networks (manually or automatically). I have roaming set up on the settings so it should connect.
When I click on the only available network (NOVA) I'm taken to an EE troubleshooting page which I can not get past. Any help much appreciated.
What settings is it that you've got roaming setup? There is no phone setting to enable roaming, only to allow "data roaming" which is giving the device permission to use mobile data whilst already roaming.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
