My phone doesn’t have network in Thailand
Sisi1984
Is anyone can help me? My phone doesn’t have network in Thailand
Is your phone PAYG or pay-monthly?
If PAYG - had you used it in the UK first, before travelling?
If pay-monthly - did you enable international roaming, by texting ROAMING to 150 before leaving the UK?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
