Roaming doesn't work inTurkey
prhmma
Hello
I am in Turkey and I cannot use any services.
I have Roaming ROW enabled as a part of my contract. I am not PAYG.
I can manually try and connect with Turkish networks but they say (forbidden) and they kick me out in 30 seconds.
Vodafone is not connecting
auto select network doesnt work
I am using e-sim
Northerner
Hi @prhmma
Tried restarting your device and trying again.
That forbidden notice is an error with the authorisation process. Did you activate roaming on your account before leaving the UK. (The roaming add on makes no difference if roaming is not activated on your account).
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
