on 24-01-2023 01:01 PM
Hi my mums number is unknown and when she rings my mobile it goes straight to voicemail I've checked everything and the only thing I have changed is my ee plan. It's quite annoyed especially if it was an emergency. Any suggestions how to resolve this
on 24-01-2023 01:15 PM
Hi @Jules242
Welcome to the community.
How is your number shown in your mum's phone? What happens when she dials your number from the keypad manually?
on 24-01-2023 06:25 PM
Calls going direct to voicemail when your phone is in-service often means one of two things..
1: You have inadvertently set a "Do not disturb", this will affect all incoming calls unless any numbers are specifically exempted.
2: You have inadvertently blocked a particular number, this would also cause incoming texts to fail.
on 29-01-2023 05:55 PM
on 29-01-2023 07:09 PM
Do calls from your Mum's phone to any other number, show caller-ID?
Incidentally, if calls from her number to your phone are shown as unknown, this appears to contradict the previously reported symptoms of the call not ringing.
Calls either ring on your phone, or they go direct to voicemail.
