Travel to US. Is Roaming Further the way to go?
thusband
Valued Contributor
Valued Contributor
We're travelling to the US for three weeks in April. The options are a little confusing. I'll want mainly internet access for navigation. I'll probably make less than a dozen phone calls.
Roaming Further seems to make sense but I'm not clear if the monthly charge covers it all or would I be better off buying a SIM card over there?
Yes, the Roam Further Pass will cover all your usual UK allowances there with up to 50 GB data per billing month if you have more.
Remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
