Mobile usage overseas
Calebkovats
Hi I’m overseas have an ee account, I’ve stopped receiving texts to my mobile number, I use this number for 2fa and I’m not getting sent my codes anymore. Please help, I’m currently using an eSIM in bali so I have both numbers active, it was working before now it’s
@Calebkovats : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Are you receiving other text messages? Can you make & receive voice calls? Does your phone show mobile network coverage? That's a requirement for calls, texts & mobile data abroad.
