I can't send text messages and do calls on my phone.
they4sieq
I was bought EE PAYG Sim Card in UK. When I land at Poland, I can't send messages on my phone. When I switched my sim card to Huawei Y5 2018 it doesn't work nothing, LTE, Text messages and calls. I switched this EE sim card to previous phone to check this and the same. I have announcement when i do call "Your calls are not cofigured" or something like that.
12 REPLIES 12
@they4sieq   Did you activate and use that sim in the UK first? If you didn’t it’ll not work abroad.      Also to use a PAYG sim in the EU you  need to purchase a roaming add on you can not use any pack allowance until you do.
Yes, I activated it and used it in UK before i leave the country i bought 10£ Subscription Pack/
How can I purchase this roaming add on?
Leanne_T
Hi @they4sieq
Did you make a call or send a text on the EE network before travelling?
Do you have any signal showing?
I did make a call but not send txt.
Yeah i have signal in Orange
Did you receive a msg upon arrival telling you about the charges for roaming in EU on PAYG? Did you buy 1 of the "Roam Like Home" add-ons to be able to use your UK pack allowances there?
I did receive a msg with charges and i didnt buy "roam like home" addons
Leanne_T
Hi @they4sieq
To activate the roam like home option, please see the below information;
  • £2.50 for 24 hours - to activate this add-on text ROAMEU1D to 150.
  • £10 for seven days - to activate this add-on text ROAMEU7D to 150.
Our Pay As You Go charges for roaming in the EU, Help page has full details 🙂
Then obviously you can't use your pack in the EU & so you will need credit to make calls & texts. Have you sufficient?
I will buy it soon maybe.
