27-04-2025
		05:03 PM
 - last edited on
		27-04-2025
		07:37 PM
			MikeT
Hi, I am Ee customer and I cannot make a phone call I am in Turkey
27-04-2025 07:27 PM
More questions than answers I'm afraid! Does your phone show a connection to a local Turkish network? Have you been able to make calls in Turkey on this trip previously? Can you send or receive texts? Can you use mobile data?
Are you on PAYG or pay-monthly?
27-04-2025 09:39 PM
I cannot even call 150 WhatsApp is working but cannot call no one else
27-04-2025 09:54 PM - edited 27-04-2025 10:06 PM
@Durkin1990 : Did you receive a Welcome text upon arrival?
27-04-2025 10:05 PM
Please respond to your original thread using the "reply" function rather than adding to another existing one started by someone else.
Are you using WhatsApp over mobile data or WiFi? Please see the questions already asked of you, in previous responses above.
