Going to Spain
Yaga23
Hi, do I need to do anything in order to be able to use the phone while in Spain?
I have a basic plan
Christopher_G
Hi @Yaga23
Welcome to the community.
You need to make sure your phone is enabled for roaming and calling abroad in your My EE account.
When did you take out your plan? If it was before 7 July 2021, you will be able to use your allowances as you would in the UK at no extra cost.
If it was after 7 July 2021, it would cost £2 per day to use your allowances.
You can see all other costs and add-ons on our online roaming tool.
Christopher_G
Hi @Yaga23
As it is part of EU, you may use your usual UK allowances there with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £10 / month.
If you are on contract, remember to text ROAMING to 150 before you leave UK to check roaming is enabled on your account.
