Data roaming France
Winston1874
Any ideas why this is not working, contacted 150 but no help, all settings correct and checked. Having to contact again, seems to be a common issue.
not impressed
Schockwave
@Winston1874 , just to add to what @bristolian  has written, have you tried a manual search, by going into networks and doing so?
