Cant use phone aboard help
Jayde-lsx
Hello my data doesn’t work aboard unable to use my phone can you urgently help me
Northerner
Hi @Jayde-lsx
If you haven't activated roaming then you'll need to call EE CS over Skype and WiFi using the number in my signature.
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
