Network connectivity
VeryUpset
I’ve just arrived in Switzerland and have no network connection, EE is incapable of helping me. What do I do?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
VeryUpset
I’ve had no network connection for 10 days abroad and at home. EE say everything is in order. I’ve checked with Apple, the iPhone 12 Mac Pro is fine. What is going on, anyone know?
James_B
EE Community Manager
Are you using a pay as you go or pay monthly plan, @VeryUpset?
Are you now back in the UK?
Assuming you're on pay-monthly, have EE CS confirmed that full global roaming is enabled on your SIM?
Manually connecting to all available local networks is often a good fix once the facility is enabled.
If you had issues abroad and are now in the UK - with identical symptoms - your issue may well be account/SIM-specific.
