on 21-07-2025 04:05 PM
Im getting not registered to any network, I cant even phone ee to speak to anyone.
on 21-07-2025 04:08 PM
on 21-07-2025 04:10 PM
Ive restarted several times, I don't have another phone to use
on 21-07-2025 04:16 PM
If you could answer the other questions asked by @Northerner and not just the last one, we may be able to help you to figure out what the issue is.
on 21-07-2025 04:25 PM
Hi ,
Im in the Uk , im on a monthly contract direct from EE
on 21-07-2025 04:30 PM
ANY network? How many do you think you should be able to connect to. If you are in the UK you'll only have EE network available for you normally.
Or are you trying to say that you are roaming abroad and can't connect?
on 21-07-2025 04:58 PM
im in the uk, but cant get the ee network
on 21-07-2025 06:53 PM
Hi @TeeSphotography
Do you get the error all the time or only when you do something, like make calls?
If you try a manual network selection, which networks show in the list?
(For android phone, go to Settings > connections > mobile networks > Network operators > switch "automatic" to OFF.
Wait for it to load with networks.
Or for iPhone please tap Settings > Tap Mobile Data > Tap Network Selection > Tap the slider against Automatic to turn off.
Wait for it to load with networks. )
You mentioned you don't have another phone, but if you have access to somebody else's mobile phone, like a friend or family, can you test your SIM card in their phone to see if you get connection?
Ali
