Can't use caps lock on my phone - how to enable?
Byron12
Hi
i would like to use caps but I can’t, the telephone doesn’t let me
could you help?
[Mod edit: title added]
1 ACCEPTED SOLUTION
Mustrum
@Byron12   which phone do you have?
On my phone, pressing the shift key enables the next letter to show as a capital, but pressing a similar key below the shift key  turns on caps lock which then makes all of the keys show as caps until switched off.
HTH
@Byron12 : Follow Set up and manage Spend Cap
Mustrum
HTH
