on 16-06-2026 04:49 PM
I'm on a 20GB SIM plan with EE, and I recently installed the SIM to a new Pixel 10 Pro XL.
This works fine, however it only connects at 4G speeds. I know the phone supports 5G, and I can't see a way to enable 5G anywhere in my Android settings or within the EE app itself.
I'm not sure if I need to buy this as an add-on, or upgrade my plan. The EE app offers no such options. Any help would be appreciated.
on 16-06-2026 05:22 PM
@p_one : You shouldn't need to enable 5G especially if it present at your location.
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area. You may also Report a Problem there.
on 16-06-2026 05:37 PM
Yes, I did use the coverage checker and confirmed that 5G is available in my area. I'm fairly central in London.
16-06-2026 05:42 PM - edited 16-06-2026 05:44 PM
Not the Coverage Checker but the Service Status Checker.
On my Samsung there is Settings > Connections > Mobile Networks > Network Mode > 5G preferred. Have you something like that switched off?
