Can’t subscribe to roaming. I am in Paris.
Rinapanchal-75
Hi. I am in Paris and am unable to subscribe to the daily roaming for £2. Texts will not send and even selecting data roaming is not working. Can’t call 150 for help.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
