Showing results forΒ
ShowΒ Β onlyΒ  | Search instead forΒ
Did you mean:Β
I need help to active roming im on my country romania πŸ‡·πŸ‡΄
Ciprian22
@Ciprian22  Are you a contact or PAYG customer?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
