‎24-07-2023 04:19 AM
‎24-07-2023 05:25 AM
@lucianadiana060 : You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2.29 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £15 / month.
On PAYG there are charges for using your pack allowances in the EU of either £2.50 / day or £10 / week, to be taken only from your PAYG credit, not your recurring card payment. If you opt for neither you will be paying standard rates for calls & texts.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
‎30-07-2023 08:41 PM
Hi I want to activitate roming for România
‎30-07-2023 08:49 PM
@Daniliuc : Are you on contract or PAYG?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. Otherwise on contract it's as the above Solution.
