My roming not working
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
20-12-2024 02:30 PM
Hi there just travel to romania and my roming it's not working, I got only emergency calls
Can anyone have a look please?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
20-12-2024 02:53 PM
