Abroad
Thomasclarke89
I’m currently in turkey , it won’t allow me to txt 150 for roaming and I have no service
only when I connect to wifi
please help
@Thomasclarke89 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Normally it just transfer over when I go away . Im on contract . I will try customer services if I can ring them ok wifi
If you have previously used your phone abroad, then one of two things is likely happening here.
1: You have EU-only roaming enabled, and you are now outside the EU.
2: There is a problem with the specific local network you're connected to currently - manually selecting an alternative often resolves.
