Abroad no coverage even with roaming
Zahralouise1739
I haven’t been able to use my data neither receive calls or use data , please , I request a call back urgently
@Zahralouise1739 , Regardless, this is not customer service, but a public forum, and so no-one from customer service will give you a call back, it is up to you to ring them, using the ways @bristolian has written, which also is in my signature.
@Zahralouise1739 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
@Zahralouise1739 wrote:
I haven’t been able to ... receive calls...I request a call back urgently
Adding to the responses... a callback would be another call you can't receive!
Follow the other advice to contact CS yourself, and request your roaming facility is enabled.
