4G ROUTER AND ROAMING
HARVEYPIN
I have a new 4g mini router, I want to know if I can use this roaming in the EU?
I need it for work when overseas.
@HARVEYPIN  Yes it will, are you on
contract or PAYG with this device?
I have an EE contract with unlimited data I am using that.
You may use your usual UK allowances in EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £10 / month.
If you are on contract, remember to text ROAMING to 150 before you leave UK to check roaming is enabled on your account.
