19-04-2023 05:44 PM
19-04-2023 06:12 PM
@lesnorman Is that all calls ?
19-04-2023 06:44 PM
no just my wife trying to reach me
19-04-2023 07:23 PM - edited 19-04-2023 08:12 PM
hi @lesnorman
please refer to @Chris_B advice regarding possible call-blocking.
kind regards, OldSchoolTech
19-04-2023 07:45 PM
@lesnorman Have you accidentally blocked her number on your device? If you’ve done thiis this is what will happen.
19-04-2023 07:46 PM
@OldSchoolTech It’s nothing to do with call ring time the call is going straight to voicemail.
19-04-2023 08:09 PM
hi @Chris_B
thanks for clarification. (i'll remove "how to extend ring time" guide from this thread) and hopefully, @lesnorman will give us feedback about his issue.
as you indicate he may have accidentally blocked his contact's telephone number. from memory, this is very easy to do on later android phones, which have an internal call-blocking feature (i think)?
unfortunately, my pixel 4 (android 13) died on me last week at work, so i cannot verify this "internal call blocking" feature. of course, there are various call-blockers also available on google playstore he (may) also have installed.
hopefully, he'll post back on this forum, and let us know 👍
19-04-2023 08:42 PM
Does your phone show signal indicators when incoming calls fail?
30-06-2023 10:17 PM
Just some
01-07-2023 08:04 AM
