WIFI calling not working without GSM network connection
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-03-2023 02:16 PM
WIFI calling was meant to work when no mobile network signal is available, but in my case it does not. Also, when I'm in a WIFI call, is the mobile network signal is lost, I lose my phone call over WIFI. That happens a lot as I'm in a building with very poor indoor reception.
This has been going for months, I use a Google Pixel 6, and I can verify my calls work over WIFI just fine, as long I have mobile network signal, once it is lost, I can't make or receive any calls over WIFI.
What can I do to fix this?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-03-2023 12:50 PM
I note you have auto network selection disabled, which is not ideal. I would certainly recommend enabling that.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-03-2023 01:32 PM
Pixel 6 (Android), there is no such a setting as to what is prefer, it is on, or off. When it is on, it always uses it.
No idea what band is here where I live, this happen on 4G and also 5G
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-03-2023 01:35 PM
I've this issue since I can remember, the difference is that before I didn't work in the location that has poor signal as I do now. So the problem was most likely always there, just not easy to reproduce.
I think you tried to post a screen shot here that is not displaying for me. But I could not see any 2G requirements, which so far I know doesn't even exist anymore where I live.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-04-2023 12:21 PM
My Pixel 6 also has the "requires 2G for WIFI calling to work selected and I cannot unselect it. Odd, I was not aware I even had 2g signal here as rarely I get any 3G. So what is the point of WIFI calling if GSM network is required?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-04-2023 01:29 PM
Hi @alexbb,
If you activate aeroplane mode, then turn WiFi back on, can you make a call over WiFi?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
02-04-2023 10:28 AM
airplane mode on pixel 6 doesn't deactivate the wifi, but yeah it works in airplane mode just fine to make and receive calls.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
02-04-2023 10:39 AM
Hi @alexbb,
That's great, it confirms WiFi Calling is still working when you have no mobile signal.
I'm not sure why that message is appearing on Pixel devices but I'll see if I can find out.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-04-2023 09:20 AM
When deactivating the esim it does not work over wifi, but I guess that is how it should work as even in airplane modem the wifi calling would need to use information from the esim to call?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-04-2023 11:56 AM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2023 09:49 AM
I've been trying to resolve this with support, but so far it has been a dead end with no solution to my problem, that is why I decided to post here to see if I can get any further details. I've been battling with this issue for 1 year now with no signs of getting it resolved.
- Network problems in RH16 for 4 days now in Mobile Network discussions
- Network is down - can’t check to see what the issue is in Mobile Network discussions
- Intermittently not receiving calls, even though caller hears ringing? in Mobile Network discussions
- Data in Japan in Roaming
- Data roaming not working in Roaming
