Terrible network connection
PATSYHAYNES8
I am in Chingford and for the past few weeks the signal has been dropping in and out. EE keep saying the problem is fixed but a couple of hours later it is down again. I really need to be able to make and receive calls and if it is not fixed properly soon I will go to another provider.
Schockwave
Hello @PATSYHAYNES8 ,
Welcome to the community,
Is this in your home or when you are out and about as well?
Have you checked here:
https://coverage.ee.co.uk/coverage/ee
You can also receive updates if you register.
Do you have fixed broadband? You can then use wifi calling to make and receive calls.
