Status checker says coverage is fine
Box4
I have the same problem -noone can hear me. The status checker says coverage is fine. All my voice settings are correct. There is no fluff/foreign objects in mic
Your "me too" post has been moved to a new thread. From your description, you've used the "check coverage" option on the webtool, not the "check status" facility to search for known issues, and report ones not shown.
What are the voice settings you refer to that you've checked, and is this loss out outgoing audio permanent on each & every call? Or does audio come & go? Can you use mobile data whilst on calls?
