Recurring seasonal signal loss, Fleet GU51 (Tavistock Road/Calthorpe Park area)
max1000000
Every year, once the weather turns hot, EE signal disappears completely along a fixed stretch near Calthorpe Park in Fleet, Hampshire (GU51), roughly from Merryvale Road to Reading Road North. It comes back as soon as I get closer to the town centre. This has happened every summer for several years and clears again by autumn.
EE's own coverage checker rates this postcode "Excellent" for both 4G and 5G, outdoors and indoors, which does not match what I experience on the ground.
Has anyone else in this area noticed the same pattern? I would also be grateful for any insight into why this happens every year in this specific spot.
I would prefer to sort this out over email or in writing rather than by phone, if any EE staff reading this are able to help that way.
@max1000000 , there is no email to customer service, so you would have to ring them, or if you can, register, report and expect updates via the app checker.
There's a couple of things that can sometimes cause seasonal issues such as this. I can only speculate as to what may be at play in your specific area.
Telecoms equipment is as susceptible to overheating as any other kit, sites have in-built cooling but if this fails then a shutdown will soon result. This would create a temporary outage on that site, but not to the degree you mention.
The summer months can cause trees and other vegetation to grow : If a radio site uses microwave to backhaul to the core network, and trees grow above the height of the microwave link, that comms will get broken and cause an outage on all the equipment reliant on that link.
I would recommend reporting your loss of service using the status tool initially. It sounds like you've used the "check coverage" option, follow "check service status" instead.
max1000000
Thanks bristolian, that's really helpful. The microwave backhaul point makes a lot of sense: it would explain a complete loss on the whole site rather than just weaker signal, and why it clears once the leaves drop. I'll bear the overheating angle in mind too.
One snag: I tried the "check service status" tool as you suggested, but it just returns "This service isn't working right now" every time, whether I'm logged in or not, so I couldn't report it that way. Is there another route you'd recommend?
And out of interest, do you know if the mast serving the Calthorpe Park side of Fleet is likely to be on microwave backhaul rather than fibre? If so, seasonal tree growth on that link would fit the pattern exactly.
There's two macro sites providing overlapping coverage to that area.
max1000000
Thanks, that's useful to know. Interesting that there are two overlapping macro sites, because you'd think that if one had a problem the other would keep me covered, yet the signal goes completely. So something seems to affect both in hot weather.
Good news is it's working fine again today, so it does seem to be tied to the hot spells and clears on its own. My main worry is being ready for the next time it happens.
Given that, two practical questions: when it next goes, what's the most reliable way for me to report the outage live while it's happening (since the status tool just errors out for me)? And can this be logged as a recurring seasonal issue for the area, so a report next summer isn't treated as brand new? I'd much rather handle it online or in writing than over the phone.
