on 15-01-2025 05:49 AM
I have only just realised that the subscription for Roaming Abroad is on a monthly recurring basis. As such I have been paying for this several months after returning from holiday.I
s there an easy way to stop the subscription as I cannot seem to locate how to do this
Solved! Go to Solution.
on 15-01-2025 08:06 AM
If you're asking about the £25/month roaming pass, then you can text STOP ROAMING PASS to 150
on 17-01-2025 11:57 AM
Thank you for your advice which has been most helpful & is much appreciated 👍
