on 28-07-2022 02:30 PM
Hello,
I have an iPhone 13 pro, am with EE and have 100GB of data which I am nowhere near running out of.
I seem to have an issue in certain locations, unfortunately one of which is my desk whereby it shows a good 4G connection along the top of my screen however nothing seems to load.
Typically if I try to do something it times out or tells me that I do not have an internet connection.
If I run an ookla speed test it just says 'Connecting...' until it give the error 'ERROR Can't reach Speedtest. Check your internet connection and try again'
I have tried altering a multitude of settings, in the iPhone settings and also resetting the network settings but no joy.
Could anyone help with this?
on 28-07-2022 04:06 PM
Have you checked your local network for issues?
https://coverage.ee.co.uk/coverage/ee
Try restarting your device.
on 29-07-2022 09:09 AM
Thanks @Northerner I have tried the old turn it off and on again a few times. This has been an ongoing issue for months in all honesty so had plenty of reboots, software updates, etc.
I am at my desk right now, have four bars 4G, no internet connection and the EE coverage & network map is showing no issues for this postcode.
on 29-07-2022 11:22 AM
Thanks for posting 🙂
Do you know if any other EE users have the same problem?
Speak soon.
on 01-08-2022 08:03 AM
None of my colleagues are with EE but they don't have issues which leads me to believe it isn't the building/wall thickness or anything like that.
01-08-2022 10:03 AM - edited 01-08-2022 10:04 AM
Thanks @Sarahandjamie
In this case, I would suggest reporting this on our network status checker, if you select 'Check Status' you can report this to our network team.
They will get this looked into and keep you updated.
Thanks.
on 21-09-2022 10:48 AM
Hello, Leanne.
Our IT guy in work actually had the same issue when he was with yourselves. In the end he switched to a different provider.
on 21-09-2022 11:19 AM
on 21-09-2022 12:46 PM
Does your phone show a VoLTE/4G-calling symbol when this is happening?
on 29-09-2022 08:04 AM
Hi James, yes I have and I have had a text from EE stating that there is no issue with this network.
It would be good if someone was actually sent out to see if they have signal here though.
I have since spoken with other colleagues, many of whom had EE and have now moved to other providers due to their 4G never working in work.
