Phone and signal problems
Haider16
I bought iPhone 16 pro max recently unfortunately, the signal (network connection) is not working properly. I have been reported multiple times to the EE shop assistants however they didn’t fix it.
I could not work my job because of connection (signal).
 I am taxi driver
15 REPLIES 15
Yes I am struggling to do my job
I have been reported for the EE shop assistants however they didn’t care
I’m the only one who pay their bills
@Haider16  have you tried cleaning the SIM card take it out give it a wipe and put it back in.
Northerner
Hi @Haider16
Where did you get the phone.
Have you tried the SIM in another device.
Yes
Katie_J
Thanks for getting back to me @Haider16.
Have you been able to search your area using the Network Checker?
Can you confirm if you experience this both indoors and outdoors in multiple areas?
Katie
Instinctively this sounds like a phone fault, but SIM or network wouldn't be impossible.
Phone or SIM would be indiscriminate and affect all locations - a 2way SIM-swap would ID which. Network fault is likely to be location-specific.
Your mention that this problem happened when you got a new phone, is quite telling.
