27-11-2026 08:44 AM
Why is it that I can use my mobile phone at home, within a metre of an EE signal booster, with the "make calls using WiFi" option activated, and yet the signal is still so woefully bad that the conversation is unintelligible and the line drops?
Please, EE, provide a solution.
27-11-2026 09:22 AM
Do you have the same issues if connected directly to the router over via the extender.
27-11-2026 01:58 PM
Yes. Unfortunately the same issues occur if I am next to the router.
27-11-2026 02:06 PM
@Yorkshireman57 Are you actually connected to the router or the extender when this happens ? Have you unplugged the extender to make sure you are connected to the router ?
27-11-2026 02:11 PM
No. The extender/booster is in another room. It was set up that way by the installer.
I was told that the signal would be available throughout the whole house by way of the boosters. There was no instruction to disconnect the booster if I wasn't in the same room. That does not seem practical to me.
27-11-2026 02:46 PM
It's possible that your calls are not being carried by WiFi-calling but by the mobile network instead. WiFi-calling is designed to only kick in when coverage levels drop below certain levels, which would fit with your comment about garbled audio and line drops.
If you're using Android, there is often an option in your phone settings to toggle between "WiFi-preferred" & "mobile-preferred", toggling this may help in testing. I don't believe Apple phones have this option.
All this presumes that other internet-based functions on your phone, are otherwise working over this WiFi connection - which would also tend to rule out an issue with your router.
