Nov 27, 2025 CENTRAL LONDON | Edgware Road Area
bays
LITERALLY ZERO SERVICE BAR | Messaging prompts me to call EE but calls (ugh!) obviously do not go through since there is no network/ service bar! NEED URGENT HELP!
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
Northerner
Hi @bays
Are you PAYG or pay monthly contract.
You have a message to call EE?
pay monthly customer~
it shows there's a problem in my area but i received an email stating it was solved but alas it's still not working and for some reason wifi calling isn't working either :((
If problems are persisting and the status checker reports no known issues, use the "report a problem" link to send further details.
Have you been able to use WiFi-calling previously?
