NETWORK BANDS
mE8419
Hi
I am looking at purchasing a Chinese phone which states it's uses BAND n28a for 5g network yet on EE it states it uses BAND 28 for 5g does this mean I wouldn't get full access to 5g?
Would VoLTE still work?
Cheers
EE deploy 5G on multiple frequency bands - 700Mhz (N28), 1800Mhz (N3/B3), 2100Mhz (N1/B1), 2600Mhz (N7/B7) & 3500Mhz (N78)
There is no single band that's "standard" as such, deployment does vary although lower bands are used for coverage & higher bands for capacity.
VoLTE = Voice over LTE = Voice over 4G
VoNR = Voice over New Radio = Voice over 5G. This requires 5G-Standalone support.
The simple answer to "will xyz work" with an independently sourced phone, especially from foreign markets, is to try it. Make sure you have alternative arrangements and/or a returns arrangement, in case of negative results.
6 REPLIES 6
Colstalex
Expert Contributor
Expert Contributor
I understand that n28a uses only a part of the n28 spectrum. Looks like EE's allocation of n28 overlaps by a small amount on n28a. What other frequencies does it support, EE also has n1, n3, n7, and n78. I wouldn't buy the Chinese phone if the only common band is n28/n28a.
Not sure about VOLTE/VONR.
Hi
The device supports lots of 5g bands including N1, N3 and N78.
My question is will having N28a and not N28 cause any issues with 5g?
Hi
I don't want to purchase something that may not work properly.
EE deploy 5G on multiple frequency bands - 700Mhz (N28), 1800Mhz (N3/B3), 2100Mhz (N1/B1), 2600Mhz (N7/B7) & 3500Mhz (N78).
The device uses all the above bands EXCEPT for N28 as it states N28A.
I can get a global version of the device which includes band N28 but it's nearly £300 more and every saving helps now days
Colstalex
Expert Contributor
Expert Contributor
I do t see why it should cause issues, not supporting a band fully shouldn’t break anything. I suppose the bigger unknown is whether VOLTE works, without that you would stuck on 2G for calls, assuming it supports EE’s 2G frequencies.
