No service - Harrogate
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-10-2024 03:25 PM - last edited on 14-10-2024 04:07 PM by Christopher_G
Is anyone else seeing poor signal / coverage with EE in Harrogate? I'm at work HG28QT inside but sat by the window and currently have between zero and 1 bar although the 5G logo is being displayed. running speedtest app I get 8.62 down, 0.91 mbps up. The EE coverage map says I should have much better than that.
is a mast down or something?
using a Samsung S21
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-10-2024 03:50 PM
Is this a recent problem? Sounds like you've used the "check coverage" option on the webtool rather than "check status" for a search against known outages.
I suspect you may be on the edge of 5G service and your phone is preferring that, to a stronger 4G layer. If so - this would be entirely by design.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-10-2024 04:03 PM
right now I have 1 bar and an E symbol.
the speedtest won't even run!
it was never this bad in the recent past
how do you check if a mast is off-line?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-10-2024 05:26 PM - edited 14-10-2024 05:26 PM
Try toggling flight mode if you're on 2G, see if this reconnects your phone to 4G/5G service.
Local faults can be checked via the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker - with a follow-on option to "report a problem" if necessary.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-10-2024 07:12 PM
tried a flight mode
coverage says Excellent coverage 4G, in and outside. no way thats true atm
report submitted
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-10-2024 09:34 AM
Do you find that the signal improves if you move out of that area? @SteadyT
The network team will have a look into the problem report and get back to you as soon as they can.
Michael
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-10-2024 12:52 PM
It's still poor but different, that's to say at HG28QT now I have a 5G symbol and zero bars. In the middle of Harrogate town center I had 4G and 1 bar this morning.
Last night at home I did a speed test, in the past I've had fantastic speeds e.g. 80 -90 down. last night I got 5.37 down, 0.17 up
something has definitely changed in Harrogate
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-10-2024 12:55 PM
Thanks @SteadyT
Keep an eye out for a text or email from the network team with their findings.
If it does come back to say they haven't found anything, I'd recommend getting in touch with our tech guides so they can have a look into it further for you.
Michael
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-10-2024 04:52 PM
I got an email from the network team saying they can find no issue in my {Home_Postcode}. I've just run another speed check in my home postcode and I'm getting 113 mbps down and 38.1 up which is fantastic.👍
The main issue thought, was at work HG28QT, could the network team do similar check's / actions for HG28QT please?
Many thanks
Steve
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-10-2024 05:05 PM
You can raise a report on the status webtool for any UK postcode where you believe there to be an issue.
